althom40
- 1.2m dish on Astra 28E . Plus Motorized 850cm .
TM3500D and 6800HD receivers. Freecom 1Tb ext-HDD.
Openbox S10 Redline 3000
- Eastern Algarve 37n 08W
Had this problem for some months. With a direct cable input into the LNB input all channels OK.
Take a loop through to my TM5300D and only the lowest Tp ( C4 Film4 More4 ) signal breaks up.
Feeding both Rx's directly then there is no problem.
If I use a back-back connector with a very short lead into the S10 only the same Tp/channels are affected.
If I put my hand around the cable near the LNB-in then the picture breakup stops.
I have chopped a bit off my feed cable, remade connections, opened up the S10 and remade
the solder joints around the little LNB input circuit board and its still the same.
I am guessing that it is some kind of screening problem?
