Odd Matrix Reloaded problem
Satellite1
matrix reloaded cam
Bognor Regis
Have matrix reloaded and DSR 9500AT receiver (sammy) embedded cryptoworks.
Matrix showed as 'Not Installed' (both slots tried) so reflashed bin, reflashed xilinx, tried different firmware still not showing.
Re-flash matrix with UCAS 3.0 Full dump bin file, it shows fine in receiver and it works fine.
Try re-erasing and putting firmware, same problem, 'Not Installed'. If I leave too long in the receiver to initialize, receiver crashes and have to reset by power down.
Tried receiver update via hyperlink (dont have OTA update) but get timeout.
What is the problem I dont know, I hope you can help since you are usually very informative.
Thanks in advance.
