- 80cm Motorised.
- North York Moors
We had a new Boiler fitted three years ago and, after many years previous experience, have left it well alone, preferring instead to do breakdown maintenance only.
Even so, the last Boiler was a pig to dismantle and re-assemble.
In the past few weeks there has been an occasional whiff of kerosene, so I thought it might be time to look at the new Boiler.
Wow, what a difference: The beast is far better designed for easy maintenance and it took me a bare hour to remove, clean and replace the Condensate Trap, to remove the Burner Assembly, clean the spreader and replace the nozzle, to vacuum out a very small amount of debris from the combustion chamber and, after refitting the Burner, to access both the primary and secondary Heat Exchangers and remove, clean and replace the baffles.
No visible oil leaks, so hopefully the smell was due to a worn Nozzle (They are supposed to be replaced Annually). All seems aok now.
Very little soot, too, so I'll hang fire for a couple more years before getting an Oftec guy out to set it up again.
Cost?
Around five quid!
Cost?
Around five quid!
