hexah
- Oct 7, 2009
- Age
- 17
- motorized Gibertini 85cm, fixed dishes from 1m to 64cm, generic FTA HD RX, TBS DVB-S2 PC card, a pile of bits and pieces
- Hadrians Wall
. . . since the 100XP dish is part of the planned upgrade (together with a single black ultra or red rocket to squeeze every last drop out of the Astra 2 signal).
Needing to squeeze the most to get a signal that you want to watch regularly is a bad sign. What you need is a good rain margin and that means getting a larger dish, there is no other way.
Reading around if I lived where you are in France I would be inclined not to go for the Gibertini 1.25m but to get a generic 120x130m dish (=1.25m) with the same gain at half the price. 19e and 13e will be through the roof regardless of what you use and any old bracket will do. You can get them on 35cm dishes.
The 1.25m won't look any bigger than the 1m on the wall, you can spray paint it to blend it in and most importantly you should be future proof. You don't want to be fannying around with it again in couple of years.
I would only use white coloured LNBs due to the intensity of the sun for most of the year. Nothing but white. Electronics get noisy and fail sooner in the reflected heat. You could use the white Opticum with the 1.25m if you wanted an octo on 28e only €22 or a Smart Titanium Quad €14 and have a decent rain margin.
If I used a Black Ultra I would spray paint it white, I have painted dark grey LNBs white when I had my big dish up because the reflection is so intense (and the sun hardly shines here!).[/quote]
