out of room on motor?
edthekid
come on you villans
azboxhd
fortecstar passion hd 90cm motorised dish
diablo cam,
dudley west midlands
put dish up where old sly dish was............got 68/70 q/s on thor with usals
picks up hotbird 13........then fails to get astras ....any of them dish turns on pis$
and seems to run out of turning on motor................dudley west midlands stumped
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
I am afraid there is insufficient information in your post to understand
a: What you are trying to do
b: What you have already done to be so unsuccessful and hence disatisfied
What does Turns on pis$ mean?
You will have to help us to help you
Whwn I read that aloud, it sends like I'm sending out a mayday signal from a war zone :-rofl2
If you are having problems, don't use USALS, send it back to Thor, use standard DiseqC motorised setting and find the sats manually .
Check in your receiver menu that you haven't accidentally set any limits.
CROSSBONES
S.Wales
Thats just cracked me up:-rofl2
Ill remember that one when my motor freezes in the winter!:cool:
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
edthekid said:
turns on pis$
midlands stumped
Hi
As long as the your pole is 100% vertical it's OK.
The dish is supposed to get the droop as it turns away from the top of the arc.
Is the dish hitting the wall?
In which case, you need a larger standoff on your bracket(s).
