Lorveney
- Old Sky 60cm dish, PACE MSS 200 receiver
- North Yorkshire
Am trying to get Eurosport from one of the analogue satellites on a PACE MSS 200 receiver but unfortunately don't have a manual so don't know what certain settings should be. Could anybody help please?
The LNB is a UNIVERSAL GRUNDIG SINGLE OUTPUT LNB 9.75/10.60 GH L.O and has the following settings:
Input Low Band 10.7-11.7 GHz
Input High Band 11.7-12.75 GHz
LO.: Low Band 9.75 GHz, High Band 10.6 GHz
Output: Low Band 950 - 1950 MHz, High Band 1100-2150 MHz
Band switching: Low Band 0 KHz, High Band 22 KHz (whatever all that means). Says its suitable for both analogue and digital signals.
I am unsure about the following settings on the receiver:
LNB:
Ofsset: AFC, 0,1,2,etc.
LNB Power: On, Off
Positioner Pol.: On, Off
Dual Band LNB: No, Tone, Volt
LNB Low: 9.750 FSS A, 10.000 FSS B
LNB High: 10.750 DBS, 11.475 T-COM, ??.??? Var.
External AV:
Decoder Output: PAL, MAC, Clamped, FLAT
AV Source: Auto (goes fuzzy), DEC-V, DEC-AV
Tuning:
Band: Low, High
Satellite: 1,2,.....64
Tone: On, Off
Ext. Switch: On, Off
The TV is standard small portable connected to receiver by Scart.
Any help gratefully received.
LNB:
LNB Power: On, Off
External AV:
Tuning:
Band: Low, High
Tone: On, Off
