pace mss 300 manual
c20rjm
Visit site
Glasgow
does anyone know where either online or on paper i can get a manual for a pace mss 300.
thanks
If yo can't find one, just ask what you want to know, as there are probably several members who have owned them in the past and will still remember how to set them up. :)
c20rjm
Visit site
Glasgow
i have managed to get it to work ok, but i would like to find out all there is to know so i may upgrade to a motorised system so i would like to know tech details what i need and how to do it
Do you mean that you wish to only use this receiver on a motorised system? You would need to buy a stand alone positioner and motor, bearing in mind that there is still quite a bit available in analogue, the majority is now digital and you will probably find that it is cheap to buy yourself a digital receiver to drive a DiseqC motor and just loop through for you analogue channels.
Don't think that you'll find much in the user handbook that isn't obvious, but if you try www.analoguesat.co.uk he may have a bit more information.
Thanks for the plug :-) Unfortunately I havent got any info about setting up individual receivers, or motorising on my site. Nor anything about looping through digital & analogue signals.
(If anyone wants to write some instructions for beginners feel free, Ill happily put them online...)
LOL, sorry, wan't trying to put the ball in your court, honestly. :D
I though that it would be more likely that one of your site viewers would have a manual for the above mentioned receiver.
