Pace MSS508-IP + Philips Gregorian dish.
P
petew
Pace MSS 508-IP receiver
Humax F1-C1 digital receiver
I've got an old analogue system: Pace MSS 508-IP driving a Philips
Gregorian Dish with a Humax F1-C1 for FTA digital stations. The Pace
being used mainly to drive the dish.
The Pace 508 has gone "belly up". When the power lead is plugged in
There is a clicking sound but nothing else. The clicking sound
continues for a few seconds after the power is removed.
As I say it is an old system. Is it possible to still get the 508 repaired?
If so any suggestions as to where and who to contact would be appreciated. I live in the SW london area.
alternatively,
According to the manual the Pace 508 provides 36v DC to drive the
dish. Would a new receiver like the Technomate 5500CIP or DAPCI
which also provide 36V to the dish be a "drop in" replacement for the
508 driving my existing dish (Philips Gregorian)?
Any help appeciated, Pete.
Sounds like the power supply, it is repairable, I believe that they still do the kits at satcure, but the Technomate would be a good replacement.
jimbo
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
As Rolf says, the technomates would be a good replacement. Obviously if you are not bothered about receiving analogue channels then you wouldn't want the DAPCI. It's costs quite a bit more than the CIP. Then again if you are looking for an inbuilt hard drive as well as 36v positioner you would need something else. A manhattan for example.
P
petew
Thanks Jimbo, Thanks Rolfw for the replies.
I think it is time to update. I like the look of the Technomate
but will have a look at the Manhattan range.
Pete.
B
Burnham Beech
Have you tried the hairdryer method yet?
Stand well clear and send all pets and children out of the room first.
Seriously though, it's only a temporary solution to get the caps up to temperature.
Lancelot
Lancelot
Retired Mod
SS1.
36v H to H 62E - 61.5W
South central
For well less than a fiver you could replace the ele caps in your psu and if you don't want it then there will be a serviecable drive for a poor newbie or other deserving cause (do it & feel GooooD)
L. :)
P
petew
L. :)
Thanks for the reply. I'm used to using a soldering iron and am tempted to try.
Problem is I haven't got a circuit diagram and there are no obvious signs of damage therefore I don't know which ones to replace. Have you got more specific info? if so I would love to have it or perhaps a link to where it can be found.
Peter.
I think that they do a kit _http://www.satcure.co.uk/spares/kitlist.htm probably comes with instructions.
P
petew
Thanks. I been in touch with them and the kits are still available. I've
ordered one, should be here within three days. Hopefully it will do the trick.
Pete
