cant say i have herd of that receiver.there is not much support on the net for less common receivers.if u have a ci slot u might try one of the many cams out there.
thanks for all replies its becomming anoying with this sat reciever got t free though so i should just put up with it. with regards to the cams I also have a connax cam and matrix reloaded cam any ideas
I know that the funcard 6 is programable and should do what i need but don't know how it all works other than I require software and a programmer i can borrow a infinity programmer, but still I stuck with what to do!!!
Any help would be great!!
Any one know where I can buy funcards other than ebay not a massive believer as lost £100 in a purchase last year so trusted sites would be a plus!!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
