philh
Knowledge is power.
- Amstrad Digibox and zone 2 dish.
Technomate 1500ci+, 90cm motorised dish on a very thick pole!
- Leeds
Hi, just a quickie!
I`m trying to patch my 1500ci+ but my laptop only has a female 15 pin serial port.
The null modem cable has a 9 pin female connector at both ends.
Seeing as I could not find for love nor money a m/m gender changer that was 9 pin on one side and 15 pin on the other, I had to buy a m/m 9 pin both sides and a f/m adaptor as well (female 9 pin, male 15 pin) which allows me to connect my laptop to the receiver.
Not it is all connected, Technomate Loader cannot see a com whatsoever, autodetect or otherwise.
My question is will the marrying of two gender changers together, instead of using just the one, have caused a problem, or could it be the cable itself?
Typical of having a newish laptop which is all USB this and that!
Cheers
Phil
Cheers
Phil
