Pb using dreambox edit and dreamset
limak
dreambox
moroccco
hi,
i've been trying to organize my favorites using dreamboxedit and dreamset, but when i load them on the box (a DM 800), they dont show when i select favourites. it used to work with my old DM500.
does it have anything to do with the multiboot configuration? (i have oozoon on the internal flash and nabilo blackhole that i'm curruntly using on a usb stick).
thanks a lot
You need the latest dreaboxedit 3 and you need to save you list as type 4 settings b4 you ftp them back to the 800
Once you have a list opened in DBEdit click on the tools tab, the drop down menu gives the option to save between type 2,3, and 4 settings. Change to type 4, save and then send the file to the dreambox
Also, in the latest CVS, the option Enable Multiple Bouquets is set to NO by default. Therefore, after you upload your settings to the DM, go to MENU>Setup>System> Customize, select the Expert Mode and set to YES the Enable Multiple Bouquets option.
