PCMCIA problem
M
m_atef
Egypt
Dear All,
I have a problem that appears before I make any upgrade, which is my notebook doesn't detect the Matrix reloaded CAM when inserted in the PCMCIA interface. Please advise
M
manikm
there are tonnes of info on this, at toecuttersden.com
waverider
waverider
Salty Tech Monster Bod
Protek 9750 HD IP, Spiderbox 9000HD. Cryptik Digital H-H Mount with1.2m Oval Dish and a box in the garage consisting of 2 obsolete STBs, various Cards and a couple of cams!
South East England
m_atef said:
Dear All,
Have you downloaded any drivers yet?
D
dante1354
hi,i upgraded my MR twice by laptop and the last time i download 1.081 on it.but now it can't be start when insert in pcmcia slot by win XP .
i used the driver that was found at toecuttersden.com and other driver
please advise me.
thank you.
P
petchletch
Were you using WindowsXP the last time you updated the CAM? Have you loaded any other software or hardware onto your PC since you last did a successfull update?
D
dante1354
hi,thanx fot your notice.
i did'nt add any hardware.but installed some software.
udate was successful but when i put it on my dec3000 it didn't find it.
and the problem exists yet.
i'm waiting for your helps.
thanx
D
digidish
as I also have the same problem with the pcmcia not detecting the mr,magic,ect, it only detect's network card's I cannot change driver, I have tried to logon to toecuttersden but keep getting a bad link, anybody help!
I have posted about this here already ROLF suggested toecuttedsden
