people plz help me with my nokia receiver
M
mido18
nokia 9200 ans a straight rs232 connection 9/9bin f/f
i have bought recently a new nokia 9200 receiver and i have bought the rs232 9/9bin connection with both sides female i downloaded the new software from nokia but when i connect my receiver to the computer nothing happens as if nothing is connected my connection again is rs232 straight [not crossed] if it should be crossed plz tell me how to do it or if there is another cable to buy plz i need help fast thanx everybody
B
Burnham Beech
You need a female<>female null modem cable.
The wires must be crossed NOT straight.
M
mido18
how can i cross them ?should be all be crossed or just certain numbers and thanks so much for ur concern
B
Burnham Beech
This is from an old web site:
Null modem connections
PC 9 pin Signal type D-box 9 pin Signal type
5 GND 5 GND
3 TXD 2 RXD
2 RXD 3 TXD
8 CTS 7 RTS
7 RTS 8 CTS
6 DSR 4 DTR
4 DTR 6 DSR
M
mido18
thanx but how can i do this crossing or if there is any hardware to buy or it is sold like that
B
Burnham Beech
You can easily buy a ready wired Null Modem cable.
For instance in the UK this is what Maplins sell www.maplin.co.uk/Module.aspx?ModuleNo=13509&doy=2m5D
Or you could make your own cable if you have the components and can use a soldering iron.
M
mido18
thanx so much for ur help i realy appreciate it
