methos_de
- Pace Ver.3 SKY+ box
1,20m Dish
Quad Invacom 0, 3db LNB
P4 3,4 ghz
1024mb RAM
Geforce 256mb 6800 Ultra
- Sunny old Bristol
Saw this advertised the other day :
*QUOTE*
Sky digi dialer £ 99.00 (Euro 142.97) This item will be available soon
Enter your country dialing code eg. Germany +49:
Order PPV events from your remote control.
Now you can order PPV events direct from your remote control. No phone calls to Sky or authorised agent! No delays in activations! You are now in control!
Installation: The Sky digi dialer simply connects into the socket provided at the back of the digibox. The cable connects to your telephone socket . To watch a PPV event simply go to the channel of choice and press ok . The box will dial the Sky subscriber centre and after you enter the pin code will activate your viewing card for the event. You account will be automatically charged by Sky . It's that simple!!
*QUOTE*
Do you think this is genuine ? and if so could this also bypass the call back problem ? Apparently you just plug your digibox into it, plug it into your phone socket and the digibox works the same as if you were in the UK. If this does work would this be a solution to all the callback problems ? As far as I know the software on the digibox is responsible for ringing up SKY and not the other way round. If this gadget actually works do you think SKY would somehow be able to tell from where the box is dialling out from ? If not they would then be receiving their call back signals and would be happy or?
Methos.
*QUOTE*
*QUOTE*
Methos.
