Pixelating/glitching problem?
andel
DM800, DM600, Technomate Diseqc Motor, 90cm Dish
Panasonic 42" Plasma 1080p
Pioneer VSX-LX70 Amp
Sky HD
B & W 5.1 Speaker Setup
Popcornhour Media center
Xbox 360
Watching T.V in the UK
On my HD channels I'm starting to get problem. I've reset the lnb via the engineers menu but it hasnt helped.
Any ideas?
Could be dish alignment, the LNB misbehaving because of the heat, or perhaps even the receiver breaking down. What does the signal strength and quality display show?
Yes I was thinking it could be the heat. Both inputs signal strength and quality are only just below the top of the bar indicator. I'm about to run out of warrenty too so I'd best get onto sky!
Disconnect one of the LNB inputs and try again. If the receiver is working after that then you have a faulty tuner.
i've had this problem had it in January and recently getting a bit of pixellation on screen, the receiver is ok as tested on other dish. iffy lnb I've had and I'm on 3rd lnb in last few months lnbs for mini dishes are just too cheap and not good quality
