alex.w.russell
- Jan 15, 2008
- Age
- 53
Fortec Star FSCOII
Fortec Universal LNB
90 cm dish (not motorised)
- Hampshire, New Forest
Hi and thanks, in advance, for any advice anyone can give.
OK, I am lost and, well, you know that point when you are just exhausted from trying...
I have poor terrestrial reception; don't know why it's just normal around here. Always resisted Sky, cos I don't like Murdoch and he doesn't need any more cash (yeh, I know, silly old principles!), but gave in as I just wanted to watch Top Gear et al comfortably. Well a 12 year old neandothal comes round, grunts at me that the trees are too tall (they call it the new forest for a reason!) and is gone 60 seconds after arrival. Out of sheer spite I did a little research, made up a 28 degree east and 25 degree elevation "block" with a pipe along the top edge as a sight, fixed it to my tripod and went round looking for clear skies! Found it can be done, either by pointing through a gap or going halfway down the garden!
So, I got a 90cm dish and Fortec receiver (I suspect it's not up to your standards, but Maplin was handy!) After some playing I got signals, but I can't find BBC/ITV. More research, more trying, more confusion. I am not even sure if I am on Astra 19 degrees or that and Astra 28.2 at the moment (but think both is unlikely). I thought I had it straight in my head by looking at the channels, from which I concluded I had Astra 19 degrees. Now I am not so sure; I did the test for 2d I found on this site, by manually installing 10773 22000 H, 10803 22000 H and 10847 22000 V, as a result of which I searched and found 45 channels (mostly foreign and all scrambled!
I know information is the key for you so:
My Latitude is 50:57:58N
My Longitude is 1:42:24W
I have reception on what the receiver says is Astra 2A, signal varies but aways with a picture. Examples of channels and transponder frequencies are: Alice Sat 10774 22000 V, L1mburg 11895 27500 V and 11895 27500 V, Musica Digi 10847 22000 V, Euronews 11817 27500 V, France 3 12012 27500 V, RTL Televis 12188 27500 H. A total of 345 channels, not all vertical; that was just a coincidence the above examples were mainly vertical signals.
The Astra 2D test gave me signal strength 64 to 67 and quality 51 to 54, always with a good picture on those not scrambled. Got 45 Channels, examples being; Belsat 10773 22000 H, Guia Digia 10847 22000 V, Test CSD1 to 10 10847 22000 V, TV1702 to 1705, 10847 22000 V.
On that which the receiver says is Astra, examples stations would be:
Euro 1080 HD 10772 22000 H, Nederland 4 11740 27500 V, Portado 11436 22000 V, BBC World 11596 22000 V, RNF Plus 12148 27500 H, FR3 Toulous 12699 22000V. Total 961 channels, signal strength tonight (high wind/rain) 52 and quality 41, but usually better and still good quality, unbroken picture on those channels not scrambled.
I also get 123 channels on Nile Sat, but lets not even go there!!
Sorry to be such a bore and put so much, but I want to give the best info I can. I am a complete newbie and don't really understand even what a transponder is, other than it relates to an individual frequency being broadcast!
I figure I am either way off 28.2 degrees, or I may have to play with my LNB, but I am now so confused! I can't find the Astras further east of the position I have the dish in now, but that could be the trees. I don't mind rigging up a mast in the back garden and burying 30 metres of cable, but I would like to be sure I haven't got it wrong and can receive Astra 2d/BBC/ITV from this position first.
This is how I feel!
If you can help, I would be really grateful. Sorry again the post is so long and desperate!
Very best to all out there.
Alex
This is how I feel!
Alex
