burgasleer
- Jul 2, 2004
- Age
- 53
Forgive me for any mistakes as this is my first post.
From Total TV Bulgaria (formerly ITV Partner), I have a Digitavio S1 CX receiver, a 80 cm dish, with which my local satellite installers have tried the following combinations of LNBs:
a) 2 x Sharp BS1R9EL100A with a Micro SatEx DS21EX 2x1 DiSEqC Switch
b) 1 x Zinwell ZKF-DJ2138 3 degree Mono Block LNBF
c) 1 x Sharp BS1R9EL100A
All of the above LNBs were supplied by Total TV Bulgaria.
Despite the above combinations, they have not been successful in installing my dish, receiver and subscribed services. They have told me they have set the dish to point at 15.8 degrees east which is where the bulk of the channels in the bouquet are listed. They were using a meter, so I would have to presume that they knew what they were doing and have positioned the dish correctly.
They've left me with the single LNB (option c) on the dish pointing to 15.8 degrees east (with the two LNBs or the Mono Block, I had hoped to get the remaining channels in the bouquet that are set at 13 degrees east). With the current set up I can only get selected channels. Below are the levels for signal strength and quality that I currently getting for each transponder in the bouquet:
This is the official web page from Total TV for the parameters and settings for their channels: -http://itvpartner.com/i_frame/l_chestoti.php
I have checked with Total TV and have forced an update of software to the receiver (version 2.37.26.5), so that is all up to date and my subscription to all channels within the bouquet is valid and has been check by their call centre in Sofia.
Does anybody have any idea what the problem could be? Could the dish have been positioned incorrectly? Do I need a bigger dish or better quality LNBs?
I’m really frustrated with this as I’ve paid for 12 months upfront. I’ve had this package working before in the UK without any issues, but no luck this time around.
Any suggestions, help or advice would be really appreciated.
Thanks.
[FONT="]Transponder[/FONT]
[FONT="]Signal Strength[/FONT]
[FONT="]Signal Quality dB[/FONT]
[FONT="]B5 - Freq: 11.138 GHz, Symb. rate: 27.700, Polar: Horizontal, Modulation: QPSK, FEC: 3/4[/FONT]
[FONT="]78%[/FONT]
[FONT="]0.0 to 0.6[/FONT]
[FONT="]B2 - Freq: 11.011 GHz, Symb. rate: 27.500, Polar: Vertical, Modulation: QPSK, FEC: 3/4[/FONT]
[FONT="]93%[/FONT]
[FONT="]4.2 to 4.5[/FONT]
[FONT="]B2(SB - Freq: 10.972 GHz, Symb. rate: 27.500, Polar: Vertical, Modulation: QPSK, FEC: 3/4[/FONT]
[FONT="]93%[/FONT]
[FONT="]3.9 to 4.2[/FONT]
[FONT="]B3(SB - Freq: 11.095 GHz, Symb. rate: 27.300, Polar: Horizontal, Modulation: QPSK, FEC: 2/3[/FONT]
[FONT="]75%[/FONT]
[FONT="]0.0[/FONT]
[FONT="]C4 - Freq: 11.283 GHz, Symb. rate: 27.500, Polar: Horizontal, Modulation: QPSK, FEC: 5/6[/FONT]
[FONT="]82%[/FONT]
[FONT="]4.2 to 4.3[/FONT]
[FONT="]B6(Pink) - Freq: 11.178 GHz, Symb. rate: 27.500, Polar: Vertical, Modulation: QPSK, FEC: 3/4[/FONT]
[FONT="]91%[/FONT]
[FONT="]0.0[/FONT]
[FONT="]SBB - Freq: 10.834 GHz, Symb. rate: 27.500, Polar: Vertical, Modulation: QPSK, FEC: 5/6[/FONT]
[FONT="]93%[/FONT]
[FONT="]4.0 to 4.2[/FONT]
[FONT="]BT - Freq: 10.796 GHz, Symb. rate: 30.000, Polar: Vertical, Modulation: QPSK, FEC: 3/4[/FONT]
[FONT="]91%[/FONT]
[FONT="]2.5 to 2.6[/FONT]
[FONT="]STN - Freq: 12.525 GHz, Symb. rate: 30.000, Polar: Horizontal, Modulation: QPSK, FEC: 3/4[/FONT]
[FONT="]64%[/FONT]
[FONT="]1.4 to 1.6[/FONT]
Thanks.
