Please I need some help
atlas150
I need some help with Matrix I just got my Matrix Realoded I did alot Of reading I also have a cas2 the thing I am stuck on I load the matrix with new update I put in my reciever and read it It has the update and the keys is that all there is or is there more I noticed when I am using Cas2 and hit verify I get a error 9 is there some other program I need to put on it any help would be great I have been trying for a wile thanks
As you got no reply maybe there is all you need to know here:- Go to Tutorials and how to section. Then how to use Cas 2. Hope this helps you out. getting one myself this week and picked up some useful help here.
Hi thanks for the reply. No the answer is not on this site But I did find it some ware else The MR 112 was trying to load was a bad program I found a good one and loaded it no more error I am told if you get error 9 it is a software proplem thanks again for answering
