folkie
- Satellite, 1.2m offset motorised, Humax 5400 + Echostar LT8700
Computer, Home Network 10/100 wired, 2 hubs, ADSL router, assorted PC's home built.
- East Anglia
Can anyone help? I have a Sky polarisation problem.
I am attempting to set up a fixed sky dish in a fairly wooded area. I have a good signal, and good quality, but no Channel 5, as I am only receiving Vertical polarisation.
I checked the coax voltage when searching and had 13v for V, 18v for H OK. I next loosened the screws on the block and physically rotated it through 90 deg. A search now found horizontal channels, - really vertical in disguise, and no vertical. So the receiver and LNB must be working fine.
I have borrowed another dish to try, but still a request to search for horizontal channels draws a "no signal". I also tried moving the dish about, although I would have thought if you could see the satellite and had a good signal, you should get both polarisations at equal strength.
Anyone else had similar problems who can offer any suggestions? As I’m rapidly running out of ideas.
folkie
folkie
