Zed
- Triax TD88, x3 Inverto Black Ultras, x2 Dreambox 800HD Pro, Triax Multi-Block LNB Arm, Lots of WF100 cable, Triax 110, Superior Darkmotor, DarkGold 0.1lnb, Dreambox 7025+, Horizon USB Plus Satellite Meter
- Belfast
I'm installing a motorised satellite system for my nephew. I've installed the wall bracket, which is a 'L' shape bracket, however I can't get it 100% vertical. Well, it's more or less vertical when facing the bracket (about 0.2-0.4 degrees off) however the pole slopes backward ever-so slightly (a maximum of 2.5 degrees).
Will this have a big affect on my motor's tracking of the arc?
