guest poster
registered
- Aug 8, 2007
- Age
- 21
I did say the Invacom's got the reputation there.. but we've beaten c120s enough times to know it's not that cut and dry... although not on 2d there but 7w h's here (similar problems.... but not the same I agree). but I'd never say never ( well, apart from just then). there's just too many making lnbfs.... and too many reports of beating that feed horn on their own dish..
What do you think of the issue of the focal point that most LNBfs get on that dish without serious modifying and the F/D ratio you'll get using an LNBf.... that's not any easy mod' either to get right with those arms (unless you have the tx arm).
The internals/spec on an Invacom quad LNBf v C120 are identical.
Feed horn & feed support arms shadow are pretty low compared to the surface area of a 1.8m...
as a percentage of surface area, what do you think it is including the feed horn & arms......
