2old4this
Honorary Admin
- Cloud Cuckoo Land
A user (MrBogus) on another board is reporting that this procedure fixed his/her CAM (using a Samsung receiver)
- unplug receiver from mains
- disconnect LNB
- plug back in (leave LNB disconnected)
- receiver date resets to earlier date
- insert the MM; MM is then recognised as a Pentacrypt v1.10
- use menu option to put it in dreamload
- load Pentacrypt v1.09 (I guess 1.11 would also work)
- unplug receiver
- reconnect LNB
- plug in receiver. MM is recognised and usable.
Try it. May work for some.
2old
- disconnect LNB
- unplug receiver
- reconnect LNB
2old
