Possible to connect an external CI to a DM800 ?
2
215liverpool
1meter dish & DM500HD
Hertfordshire
Hi peeps
As the DM800 doesn't have a CI slot, is it possible to connect an external CI drive or module so I can plug a CAM into it ?
Sorry if my question sounds silly but I was just wondering if it was possible ? :-ohmy)
Many Thanks
Topper
Topper
Amo Amas Amant Admin
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
2
215liverpool
Hertfordshire
Thanks for your reply.
I want to be able to insert a CAM but aren't these products that you mention above just card readers ?
Topper
Topper
In that case the DM800 is probably not what you want as I do not think there is anything available that will suit your requirements. What kind of cam do you want to insert, most encryptions run on EMU's anyhow so none needed
2
215liverpool
Hertfordshire
I already have a DM800. I have a Tring card but I am failing to get the monthly updates using Newcs and CCcam and the combination of Newcs and Magcamd.
shumifan50
shumifan50
2xDM7025(DVB-S tuner), DM600SPVR, DM800S, DM500S HD, Triax 90cm with MultiBracket 4 sats.
Europe
Have you tried CCcam 2.1.3? No need for newcs on hte UK card and it updates.
2
215liverpool
Hertfordshire
Hi there
I've installed CCcam 2.1.3 but my CCcam info doesn't recognise the Tring card. Also it isn't showing as a local in CCcam info.
Have I done something wrong ?
