Power VU Receiver
Gaza 1
3Mtr Laser PF invacom .3 lnb and laser feed horn AD3000VAICP Cards Cams all the other Stuff
Annie 204 Spectrum
Fetihye S/w Turkey
Scientific Atlanta Power vu receiver 19 inch rack mount works but no card have seen test card on hot bird not to sure which model as it is not here with me. will be available as from the 10 th of may
Donations to the forum are required plus you will have to pay for P&P not unless you collect it from sussex, But the receiver is free of Charge.:)
If you got any Fibo mounts and motor then let me know...
i did have some 90 cm dish dishes they have gone might have a motor will have alook when i get back also had a nylon cog will let you know
