Hello,
Is it possible to mount a small (120cm) prime focus dish to a H-H motor originally designed for offset dishes? If I manage to adjust correct elevation angle to the prime focus dish, is the arch that the motor provides adequate?
The size of the dish should not be a problem since the H-H motors generally support dishes with diameter up to 120cm.
Thanks,
Martie
Thanks,
Martie
