dfdream
- DN 7020
Gemini 4
Channel Master 1.2
VBOX II
Jaeger 1224 Motor
- IRELAND
I know this was asked several times but the information is not helping me..
Setup:
DM 7020
Gemini 3.30
Necamd 6.10
Camd3.881a
I have the DB for 2-3 weeks now. When I got the DB it had the orginal image on it (ENigma) and I used to browse to the device using \\192.168.0.220 and play the recordings from there. With the new image Gemini 3.30 this is not an option. If I type in \\192.168.0.220 I get network cant be found. If I type in \\192.168.0.220\root apopup box appears but I dont know the username or password. Ive tried usernames like root, dreambox, gemini and passwords like none, db, root, admin, dreambox etc.
Is this an ftp login to the root.
I can telnet, ftp or Http to 192.168.0.220 no problem but I want to be able to play files from DB not download with FTP to pc and play. firstly can SAMBA work for the db 7020 with gemini 3.30, i have tried it but no go, this is what I did.
I downloaded samba.tar.gz from http://dreambox.gamesquad.nl/download/samba.tar.gz. I then FTP'd the file to /var/tmp.
I telneted into the DB to /var/tmp and entered gzip -dc /var/tmp/samba.tar.gz | tar xf - .
I rebooted the box but still could not browse to \\192.168.0.220.
I checked the PS and neither smbd or nmbd were running. I ran them manually from telenet with no errors and still no access.
I also manually installed the files from the zip to the locations and set the permissions on them to read and execute.
I'd like to get this feature working and would appreciate any help.
DFDREAM
Setup:
DM 7020
Gemini 3.30
Necamd 6.10
Camd3.881a
DFDREAM
