Problem flashing KAON570H pvr, please.
sputnick
DM7000S, movable dish 1m pointing at 13E, 5E and 4W. The Gemini Project 2.90 Image in Flash. No multi-boot.
Belgium - Brussels
Hello guys.
It has been alreade several days that I'm occupied with following problem.
I got this KAON 570H from a friend.
I downloaded KUP2.30 ( loader prog for uploading firmware )
Strange thing is that this receiver has been flashed with version
KSC-511HZ 13.41.6D.
Ok it is still version H/W 13.41.6D, but what has 511HZ to do with it.
Anyways I got to flash it with last patch of 511HZ, but now as I understand I have to try and flash it with right patch, which would be
--> KSC-570H 13.41.6D
I found all of them, but flash process dont start anymore.
I tried all versions of KUP loader ( normal user and engeneerd mode )
It just sais " connect successful " and thats it. Before it used to go further and started flashing process, now it just stops with successful connect.
Have anybody known this problem. Any suggestions are more then welcome.
Thank you. Good luck.
those who are interested, you never know.
Solution for this problem I found :
Whil connecting COM-cable and once the update soft is running, do not turn off receiver from behind ( the button power ), but just turn it to stand-by mode and then press "on" to power it up again.
This is when uploading will start. Apparently a lot of those Kaon's will update only this way.
Happy coding ... :)
