Problem loading CCcam 2.2.1
steve14
DM800 motorised dish
NW England
A friend of mine has a DM800 HD on a motorised dish. I'm trying to help him get CCcam2.2.1 on to his box. He has Nabilo loaded on his box and you can normally go throught the menu and just download and install it. We have done this before using this method. Every time we try to do it now it just gives the error "Sorry connection failed".
So we tried to use Dcc.exe to do it via FTP. I have downloaded the files onto the laptop and FTP them over to the box and CHMOD 755 on them. But when we go into select a cam we are not able to select 2.2.1. It only has 2.1.3 and 2.1.4 which we downloaded through the menu system a few months back.
Any help would be much appreciated.
Steve
Try to delete first versions 2.1.3 and 2.1.4, then send 2.2.1 in tar.gz to tmp and Manual Instal. Attributes 755 in .bin folder. Or you can only send the .bin file from 2.2.1 over one of the others. Change name to 2.2.1 and restart dream. I think Nabilo addons server is down...
Hi Briosa,
Thanks for the help. So I could copy the text from the 2.2.1 file and paste it over the text of the 2.1.3 file, restart and load the cam?
