Hi All,
I am having problems programming a Reality CAM with the latest patch.
I have done the OTA upgrade so and the CAM is now running OmniCrypt 1.0.5 and so I am now trying to patch the CAM in my laptop.
However, when I plug the Reality CAM into my Laptop;
1. It seems to take ages for anything to be recognised.
2. Machine eventually beeps and if I then check in Device manager a new device has been added. But it is added under 'Other Devices' and identified as PCMCIA MTD-0002. (Note it is not added as a PCMCIA adapter). I guess becasue there are no specific drivers installed ?
Anyway, then when I try and use ucas loader to program it I am unable to select the PCMCIA option under the settings menu.
The Laptop is an Acer 4601WMLi running XP professional. I am trying to use ucas loader 1.3.
Does anyone have any ideas ?
Many thanks
Clive
Many thanks
Clive
