willgreen
- Media Portal (Soon to be DM800SE), 2 Dish, 28.2,19.2, 13 and 9
- Cambs, UK
Hi, I`m having trouble recieving a few channels on my Satellite with said card. I have latest drivers from the web and I have Media Portal, ProgDVB and DVB viewer to watch tv and one of the channels I can`t get is TF1 (9E). In the tuning section of each software I get 100% signal but its not locked so any scan will not pick any channels from that transponder (12034.00). It does the same with a few from 13E aswell, I can`t get Discovery Realtime. I don`t know if its a driver issue or what. I am prob going to change the way I watch sat tv to a Technomate 5402 box instead of a PC card and XBMC PVR.
I have a New Horizons 80cm dish with a multi LNB mount, LNB`s pointing to 19.2, 13 and 9 my other dish is a 60 oval pointing at 28.2 for FTA channels running through a Diseqc switch. I have noticed that my signal on the 28.2 is about 60 to 70% on some transponders but I can`t get it any higher with the meter I have (not a good one) but I seem to get no troubles with tv channels on 19.2 or 28.2 Anyone else use this card and have the same trouble or is it just me not doing something right.
Thanks Will
Thanks Will
