I thought I had all this working ok. I have been using two DM500S clones connected together via an ethernet switchbox and all has been working well. Boxes running PLi and Oscam DVB API.
Now when I add another dreambox to the switch box, only one of the slave units clears the picture at a time. You can switch to one box, it works, switch to the other it doesn´t. A few seconds later the first one isn´t working and the second one is (Master box always working).
Also it doesn´t seem to matter what User or Password I put into the slave units (even if its not one on the Masters config file - how is this possible?), one unit clears a picture at a time.
Any idea how I can get the three units working simultaneously?
