problem to upgrade starsat 550dplus
please can you help me , when i attempt to upgrade my receivers to a new version ,the upgrade fail and my receivers is down.here is what i see when i use simpleupload program:
1-BABO
5 STPG
9- REDY
read size=(586365)
compare cheksum:(4401DCE)(4401DCE)
613: (ERR end upload:ffff0)
upload failure(flash write error).
so , is there any possibility to flash the memory with the JTAG inetrface?
i'm skilled in electronics and i want the pin's connection on HS01.
1-BABO
5 STPG
9- REDY
read size=(586365)
are you sure you have downloaded the correct rom for your receiver !?
i've the same problem with a starsat sr-x 220ci. when the system try to write the flash memory the following message appears "time out error".
