- Mar 29, 2004
- UK
I have donloaded the the TBS6983 dll files from the TBS web site and copied them into the sources folder of my TSReader installation but am getting an error message box on starting TSReader.
The message is that "ordinal 52" is missing from some folder or file? Do I need to update another file in the installation to tell TSReader that the TBS6983 dll files are valid?
If I delete the two TBS6983 dll files from the sources folder the error message box does not appear but I am then unable to select the correct source for TS Reader.
Any help most appreciated, the version of TSReader I am using is 2.7.45e
