tvbonnici
- Samsung UN55ES8000 TV with integral decoder and i-CAN 1850S tivuSat decoder.
- Malta
Hello,
I created a video on youTube at
http://youtu.be/co5V8mcDGG8
The purpose of this video is to highlight the problem I am experiencing with my Samsung UE55ES8000 TV and the Italian Freeview service tivuSat (www.tivu.tv). Using the Samsung's built in satellite tuner with the DIGIQuest SmarCAM tivuSat
http://tivu.tv/sat/prodotti/149/151/295/DIGIQUEST-SmarCAM-tivusat.aspx
and tivuSat smartcard, not all encrypted stations show. Using the same tivuSat smartcard in an ADB i-CAN 1850S decoder
tivu.tv/sat/prodotti/149/241/244/ADB-i-CAN-1850S.aspx
everything works perfectly.
In this test the same Satellite cable was used. It was first attached to the TV after which it was unscrewed and attached to the i-CAN decoder.
If you have a similar problem or can suggest a possible solution please message me. I would really like to avoid purchasing another decoder.
Thank you.
Thank you.
