Problem with CAM on Twinhan 1030A
OEB
Likes
I'm having problems getting the CI on 1030 to work. I've tried many programs, but non of them will find the CAM or card. I have a Conax and Viaccess CAM.
Old Geezer
Likes
Deepest South Wales
#2
Hi OEB,
Not too familiar with the Twinhan CI cards , although a quick search on the forum did show that You weren't alone with CAM compatibility problems.
One fellow member was having problems running a Matrix cam with a Twinhan card.
When You say You have a Conax and Viaccess cam , I imagine it is in 1 unit (not 2 seperate cams).It may be that the card with not work with multi-encryption cams.
Check out the link below for details on the card and a list of compatible cams.
http://www.twinhan.at/?tpl=/products-1-2.html
Is the FTA stuff coming through OK?If so then the card is working OK.
Have You used this combination of cam and Twinhan before with success , or is this the first time?
Hope that this has helped You a bit , and i'm sure that a member who has a Twinhan card will be able to help with the more technical stuff.
All the best with the card,
Cheers,
Old Geezer
