Problem with Conax 3.03
chuckles
After using TC in my 3.03 cam I can no longer use LCE. The cam still works with TC but as soon as I insert my season the LED on it goes mad and blinks fast and furious continuously, even when not connected to my seriel port.
Clearly something has changed inside the cam either physically or with the software.
Anyone got any ideas? There does not seem any way to access the internal menu.
The cam can't be wrecked as it still works with card, but it definately did not behave like this b4 with emu. The season used to flash intermittantly but now its as I described above??
Not the end of the world but can I access any menus?
Hmm, haven't heard anyone experiencing that problem before Chuckles, have you tried getting inot the CAM menu when on an unencrypted channels?
No way to access the internal menu (display usually in Scandinavian - Abonnement etc) , try putting the dish on a channel not transmitting from 1W and attempt the menu
Does not seem any way into it. Used to be able to access it through the emu proggy, but of course that wont work now.
Neve mind I don't suppose Conax will last much longer anyhow.
