Problem with Euro 1080 7e
Hakon
My setup
Laminas180cm P.M 60e-30w
24" SuperJack,Clark-Tech V-Box
Laminas120cm CM P.M 75e-30w
18" Superjack, Clark-Tech V-Box
Gibertini XP premium 100cm
Polar Mount, 12" Superjack
75e-30w
2 x Vu+ Duo
Sweden south
Hi does anyone catch signal from this transponder.
Eutelsat W3A 7°E
Freq: 10.880 MHz
Symbol rate: 13.333Mbps
Polarization: V
Modulation: DVB-S2 QPSK
FEC: 4/5
Channels : ex HD 1 and HD 3
I had signal last week , but after the changes 14-15 nov i can not get signal anymore at this transponder.
I have edit the satllites.xml but no luck.
I have also made a manuel scan with above data but no luck.
I catch all other channels at 7e and i have good signal.
Dish: Laminas 120cm with Smart Titanium 2nd Edition Quad LNB
Receiver : Dreambox DM 800 LT5 SP3 Bootloader #67 Enigma2 5 oct-08
i read on the net,that euro 1080 has been swtiched off also on 23.5 east,but i have not tested it if its true or not,but it sounds like its true...
or maybe the change to other satelites,and we must find them!
Yes that's true they have switched of at 23.5e
Today only at 7e.
_http://www.alfacam.com/Userfiles/File/Euro1080HDTVChannelsBySatellite-v2008-11-12(1).pdf
I have also been hunting for the Euro1080 channels on 7e. I was getting the 'clear' HD channel about three or four weeks ago. Now nothing. Even done a blind scan, without success. I'd be grateful if someone could give us a clue. I have a valid Euro1080 card that I registered a few weeks ago!
.....suppose I could contact them at the Euro1080 website to find out....
hello!
today a german satelite newsleter reports today that the channels hd 1 and hd3 now back on above freqency!
it is unclear at the moment what happens with the channels hd 5 and exqi sport,the cannot say,if the will ever come back to the satelite or not ,at the moment!
hope that helps a little bit!
Hi thanks for answers.
I find some info that the Dreambox DM800 must have an update in drivers as the function "Pilot" in setting QPSK is missing.
The problem is that i don't know how to use the updated files that i find.So i can only wait untill there will be complete new drivers.
_http://git.opendreambox.org/?p=enigma2.git;a=commit;h=6347d817582886ab7c7535b44601538749d06d5b
I too can't seem to get any of these high def channels using the Euro 1080 card and Irdeto cam that I bought at the same time as the Topfield high def receiver TF7700HSCI. I've re-activated the card on the Euro1080 website but still doesn't open any HD channels. I'm in Dublin using a 1.2m Channel Master so maybe someone can offer a solution???
Gm
