Hi all,
This is really doing my head in. First off I have searched everywhere for a solution but getting nowhere - the forum, the idiots guide and google.
I am running XP Pro SP2 on the same network as my DM800. I have no firewalls in place and I have no problems whatsoever with passwords etc in relation to telnet, ftp etc. when trying to connect to the DM800. I am also streaming to my PC. So I'd like to think I kind of know what I'm doing.
Yesterday I decided to install Samba via the online install from the Gemini2 blue panel. All went well. I then followed the advice in this thread: -
http://www.satellites.co.uk/satellite/dreambox-general/154355-using-dreambox-nas.html
In fact the smb.conf on my dreambox was already exactly the same i.e. the default install. (which does make me wonder if the one in the thread has actually been tested).
The problem I am having is that when I try to map a drive to the share //dreambox/hdd I fail authentication every time. Just doesn't want to accept my correct root password. I have tried various things proposed by people on the net but come up with nothing. It's like the two machines are using a different protocol. The samba log has nothing in it to suggest an obvious problem.
My smb.conf is currently: -
[global]
load printers = no
log file = /tmp/smb.log
security = user
server string = DreamBOX network services
workgroup = WORKGROUP
netbios name = dreambox
client code page=850
character set=iso8859-1
case sensitive=yes
preserve case=yes
short preserve case=yes
encrypt passwords =yes
smb ports = 445
[Configuration]
comment = Configuration files - take care!
path = /var
read only = no
public = yes
guest ok = yes
[Harddisk]
comment = The harddisk
path = /hdd
read only = no
public = yes
guest ok = yes
browseable = yes
The result is the same whether or not I use IP or netbios name for connecting.
If anybody has come across the same problem then please spill the beans.
Cos I is well confused. If the dreambox has the equivalent of "Use simple file sharing" and there is a button that says off then I wish I could press the bugger cos the symptoms appear to be just the same as when XP will only accept connections via guest only. ;)
Thanks alll.
[global]
load printers = no
security = user
case sensitive=yes
preserve case=yes
smb ports = 445
[Configuration]
path = /var
read only = no
public = yes
guest ok = yes
[Harddisk]
path = /hdd
read only = no
public = yes
guest ok = yes
browseable = yes
Thanks alll.
