hakkers1977
- dm800hd pvr250gb
- gorey, wexford, ireland
hi guys!
i have recently changed my setup from multi lnb to a linier motorised system after passing by the diseqc setup too, i have looked all over the internet for a good polar mount that will support my very havy 120cm dish wich is pretty good i have to say very good gain, but i couldnt find any or the once i found whre extreamly pricy so i dicided to make my own, after a week i have to say i was imbressd with my self the polar mount i made of steel scraps and a the old dish az mount parts was a great success very sterdy loose less and it looks great.
reciever tc cable out the back, set up cable mounted the motor hooked up the actuator made a few adjustements, bang!!! its working great and the signal is 82% to 90% compare to 40 to 45% i hade on badr26 befor so i packed up everything conected the cable in the motor cable in to the house witch actually runs about 40meters gowing throut doors and corners to get to the siting room and pow the positioners dos work there is a short puls two counts and then the E2
error message on the positioner, i was told that it may be the cable i was using it as a foor core alarm cable witch worked fine with the a smaller actuator so i changed it to a thiker propper four core cable witch now dosnt work either the sensor is working fine cause whwn i bring the positioner outside it work fine and wen i loosen the cable it works fine too with a couple of errors but then it work again i dont know what the story is im begining to think that its the positioner the have not got anought power out trought the cable i think its about 2.4 amps of power out wht do u all think? did anyone of u hade this problem or similar befor i need some help here please and tank u in advence.
