Problem with Manage Extensions option on DM500 HD
janu74
DM600
Win Vista
Malta
Dear All,
I am trying to download and install VLC from The Manage Extensions option found on Menu screen. When I select the VLC and try to install it, a bar appeares on screen as if DM is trying to install the extension. After some time it says on screen that the installation is complete (but I noticed that the bar has only gone up to a few steps not the full length). Infact when I go into plugins screen I see nothing there. What do you think is the problem and how can I solve this?
JOKERIB
