problems with a Magic Module
gsmserv
DreamBox7000s120HDD,MMv1.05,Fun6,CAS2(add-on)90cm satellite dish,2LNBsDISQ,BSkyB dish,HP Pavilion dv1000 Intel Pentium M processor 1.60GHz 512 MBRAM 60GbHD DVD RW,1 Mb broadb,LAN,PanasonicSA-HT520 home cinema system,28"JVCflat,wide.
ENGLAND
hello,
situation is:
ive bought Magic Module about 9 months ago
On the back of module is written
P/N : 8106/2003
v 1.05
i remember long time ago i have put this module into my dreambox 7000s.
Common interface menu said Penta 1.1
but i didnt use it till now anymore.
when i try to put know CI says DREAMLOAD. WHY??????
ive got CAS2 as well. So, ive tryed to flash it.
connected CAS2 to my laptop, run cas studio 6.1,
pressed "connect"
ive got :
CAM connected
Xilink XC9536XL CPLD Version 3 detected
Functionality not warranted
Flash unknown : Manufacturer ID : 0x0090 ID : 0x0000
Detecting CAM
Pressed Erase All
and i have "Erasing Error on Block 0,1,2,3...............34.
Erase compleated.
i extracted my Penta 1.11 rar file
ive got penta1.11.mbf (or something....), changed to .bin(just changed 3 last letters)
After that i started to write Penta 1.11
After mesagge "flashing compleated" just pressed EXIT.(once i tryed write Xilink, but the same problem anyway)
i put Magic Module into the Dreambox....and have DREAMLOAD.
ive tryed 3 or 4 times....same problem.
any idea???
thank you very much
If you power off a magic cam more than 3 times with no card inserted then the card enters dreamload mode and sits awaiting programming.
gsmserv said:
Pressed Erase All
If it is in dreamload it is already erased hence the error message
gsmserv said:
Ive got penta1.11.mbf (or something....), changed to .bin(just changed 3 last letters)
Yet another mistake....... changing the letters why?????
Sorry i cannot help you with the CAS 2 as I have never used one to flash a magic cam
because CAS cant find mbf file. In the guide is written : need to upload .bin file
So, i have changed 3 last letters after dot. Or...maybe i am wrong, do i need to change it by another way?
If you take a Microsoft document file anything.dot and change the file extension to anything.xls it doesn't suddenly become a spreadsheet. The very least you would have to do to convert a file from one format to another is run a program to convert the file to a different format.
So which guide are you referring to then I can respond???? Is this the CAS guide? a howto from this forum? another forum?
hi,
what exactly program do u mean? to convert .mbf to .bin?
thanks
and couple more questions...can anybody explain to me, what can happen if i load penta 1.11 to my Magic Module?I mean if it would be non original.I ve got 8106/2003 v1.05.as i heard it is not original card.but...i remember, when i bought that CAM was loaded penta 1.1
thank you
Please answer my question which guide are you using!!!
sorry ,mate
CAS guide.i mean during the programming.In the same window is written.Upload the .bin file.
and xilink need to upload before flashing or after?
thanks
As I explained I do not have a Cas interface I use a magic module rs232 programming card like the one shown.
I suggest you use the dedicated web site to find out how to do successfully program your module using CAS interface by clicking here This takes you direct to the correct English section of casinterface.nl where step by step details are given. Good luck
i know it's an old post but here goes :)
the cas2 software will accept both .bin and mbf
without the need to change .mbf to .bin
you need to load dreamload.bin first
when complete, change the start address to 10000
then load the penta file.
or look for penta 1.09 or 1.11 full dump
which is dreamload + penta file all in one.
when complete, put cam into receiver,
if you see DREAMLOAD, switch receiver off then on
and it should show pent1.09 or whatever is on cam.
regards
spider
