lampard1983
- HP Media Center PC
HP 6735S Laptop
- Derbyshire
Hi all, i got my new motor yesterday and will soon be moving house and will be able to put up dish and get setup etc, in the meantime i thought i would test new motor and im having problems, i have hooked up motor to my dm800hd box and used the following settings:
tuner configuration menu
tuner a: alps bsbe2 (dvb-s2)
positioner: USALS
configuration mode: simple
mode: positioner
longitude: xxx.xxx
east
latitude: xxx.xxx
north
i then go to satfinder menu
tune: manual transponder
satellite: i choose satellite i want
system: dvb-s
frequency: 11836
inversion: auto
symbol rate: 27500
polarity: horizon
fec: auto
the problem is, when i select a satellite the motor moves to it, but it goes past it
for example
if i tell it to go to 40.e it goes to 43e on motor
if i tell it to go to 5w it goes to 7w
it goes to 9e, 10e, 13e, 16e perfectly, but wont stop at other satellites, i have manually set it at 0 and reset motor loads of times but still the same problem, anyone help
cheers
just sent it to 45w and its gone to 51w
positioner: USALS
mode: positioner
longitude: xxx.xxx
east
latitude: xxx.xxx
north
system: dvb-s
frequency: 11836
inversion: auto
symbol rate: 27500
polarity: horizon
fec: auto
for example
cheers
