bearing said:Hi there,
First post here, hopefully you'll be able to help me out.
I'm currently trying to get 13E and 26E using a triax 110cm using 2x0.3dB lnb mounted on a Triax multiblock. I don't know if I'm doing things correctly but I've set the 26E lnb closest to the feed arm with the idea that as 13E is a lot stronger in the West Midlands than 26E I'd focus more centrally on 26E. The problem is that I'm getting a great signal from Arabsat but can't for the life of me get anything from 13E.
Hi, my name's Dave and I have the exact same problem.
When I got my system installed (1m dish motorised TM5300D+ receiver) I was able to get both Hotbird 13E and Arabsat 26E - but when I tried to get other satellites such as Badr [Arabsat] 6 to get LBC the Lebanese channel I lost both Hotbird 13E and Arabsat 26E.
I can get one by turning the motor and scanning (takes a long while to work) but then I lose the signal to the other. How can I get them both as was when I had the system installed?
Also how can I get LBC Lebanon as well?
Thanks in advance, Dave.
