problems with searching satellites with gimini 3,8
Turok
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
Hallo !
now iam using latest gimini 3,8 since 5 days on dm 800 ,the scanning procedure of each satelite takes very long time,up to 45 minutes!
currencly i dont have tested the nabilo image,is it also compatible with ccam,with maybe the faster sat scans?
the mean problem i have, after i make factory reset many times,i scan for example first time 28,5 east then hotbrid,then i want to scan 1 west for exapmple,set always,with the extended conected,and no diseqec switch is used,the satelite ,i want to scan,first in the tuner menü,set to 1 west,but it scans,also the 2 satelites,that i have scanned before,how can i stop this?
after the 2 satelites,that i dont want to scan,have been rescan again,it begins with the 3.satelite,that i have selected in the tuner menu,i have tried difrent diseqec settings also,over swtich but nothing will work,is there a way to fix this,that only the satelite will be scnaned,that i have selected before,in the list?
Do not hijack a thread with a post that is irrelevant to the topic.
okay sorry!:)
sometimes have to many simular questions!,then this happens!
The question was about MgCamd and keeping a sky card alive- nothing to do with scanning channels.
