Problems with Stab HH120 installation.
J
jpmm
I have a Stab motor H-H 120 an live in London. I am getting frustrated with its installation. I have got the manufacturer's manual that came with the motor but it is just not working very well at the moment. Do you know of any tutorial or some usefull instructions on the installation of such motor?
Any help would be great,
Thanks.
If you have set the scale on the motor to your lattitude (the instrucions for the Stab are quite good) and then set the dish according also to your lattitude, there is a calculation in the instructions, then found 1W, you should be close.
