Prog.dvb Audio Language Options
Alan Pee
Likes
How does one change the audio language options on Prog. DVB? I only get one language on the movie channels like TPS and D+. Plse help.
Lancelot
Lancelot
Retired Mod
Likes
SS1.
36v H to H 62E - 61.5W
South central
#2
Hi Alan - right mouse the channel and choose properties and in the drop down box in the top RH corner are the audio PID options that are currently being transmitted by that channel. If the one you want is not there then it is not available with that programme.
Rgds
L.
Alan Pee
Likes
Thanks Lancelot. I just done that and its working now. Cheers M8.
D
d_lamer2003
Likes
skystar 1 + Motorised dish.
malta
#4
Or else, Where you have the volume slider, there is a music note icon, near it there is an arrow pointing downwards, click on it (On the arrow not on the music note,because if you click on the music note, it would mute progdvb), and if the channel is transmitting in dual audio, it will give u an option which language to choose.
