Protek 9760ip Hd? or not
rich0398
Motorized 1.2M Channel Master
18 Inch Super Jack
Protek 9760HD IP
Inverto Black Ultra LNB
Earl Shilton Nr Leicester Uk
Hi all. Just in the middle of a motorized sat install ive got my dish sorted lmb etc. Just wondering wot receiver to go for. The protek 9760ip hd looks promising or a TM 5402HD. Thanks
Rich
Choice of receiver is a very personal thing - you need to decide just what you want to use it for.
rich0398
18 Inch Super Jack
Protek 9760HD IP
The more i look the more confused i get :-wow thanks for the help m8
But AS is right: What are your priorities/must-haves/don't cares etc.?
Lets try to simplify things
If you want a box thats ideal for general watching tv use then Technomates are well regarded.
if you are an inveterate tinkerer then you might want to consider a linux box.
Riverblue
Near Brighton
I've had a Protek 9760HD for 9 months now and I can definitely recommend it if you are into sports and films, not too difficult to set up either. If you need to know more PM me ( if that is allowed?)
rich0398
18 Inch Super Jack
Protek 9760HD IP
Thanks for the info, Ive had a Dream box in the past & thought i was a bit difficult to use so thats why iam thinking of getting one of the above boxes.
Thanks.
Rich
rich0398
18 Inch Super Jack
Protek 9760HD IP
I had the Protek 9760hd in the end. Can recomend it its a great box.
Thanks for all the help.
Rich
