Quatro LNB Multiswitch diseqc motor
spludlow
spludlow
Likes
120cm, DisEqC 1.2, SkyStar 2 PCI, SkyStar HD, MediaPortal, TVEngineV3, ProgDVB
I currently have a motorized system that I use with a PC.
I want to add more tuner cards to the PC and would also quiet like to use my normal satellite receiver as well.
I need some sort of Quatro LNB + multiswitch set up.
I can move my dish through software on the PC or swap over to a real satellite receiver and move it.
Can anyone tell me what happens to diseqc commands with a Multiswitch?
Likes
1,299
#2
Not a good idea to swap receivers around when controlling a DiseqC motor, it normally ends up getting lost.
How many receivers do you want to run from it?
spludlow
spludlow
Likes
I wanted at least 2 tuner cards in the PC and I have 2 real recievers kicking about that I will probably setup one day. So 4 I supose.
I only want one PC card to be able to control the motor. If I put the motor between PC card 1 and output 1 of the multiswitch would it work OK?
Also on the point of motors and swapping the coax over. In the past when testing the diseqc software I got my dish into some pretty unusable states. But whenever I hooked the TF7700 back up and went into USALS it always recovered ok.
Once a diseqc motor is initially setup won't it just always just goto a certain position when instructed?
Likes
1,299
#4
It will supposedly go to reference point when requested (zero), but in real terms they don't always and sometimes a reset on the motor itself can be necessary.
Just a quad LNB should fit your needs by the sound of it.
