Current Setup: Triax 80cm dish with quattro LNB to Skymaster MSP 58 multiswitch locked on to 28.2 E.
Would like to also point to 19.2 E. Have a Technomate DiSEqC H-H TM-2600M3 motor. I can provide power to the motor via one of the quattro LNB feeds. So, feed the Low V output from the LNB to the Motor LNB input and power is supplied to the motor. However, the signals for moving the motor are not passed by the multiswitch. (An alternative is to use two LNBs and no motor. However, aligning the two LNBs correctly (28.2 E and 19.2 E) is not easy as I don't appear to be able to provide the necessary skew angle.) Any ideas how I could get the DiSEqC moving signals to the motor with only the quattro LNB on the dish? A possible suggestion attached?View attachment 123964View attachment 123964
