Re: using an LNB with more then 1 output
marcaaron20
Dreaming Satellites
Dreambox 8000 HD,
80cm Orbital Satellite Dish
Motorized
LNB with 2 outputs, 2nd output leading to upstairs and using Dreambox 500S.
Pioneer VSX-1018AH-K Amp/Receiver,
Stockton-on-Tees, Cleveland
my plan is to feed a signal from 1 LNB into every room in the house, if I got an LNB with 4 or 8 outputs will i get a reduction in signal strength/quality??
what is the best LNB to get that gives the best outcome??
also what DB is the best?? low as possible or high as possible??
thanks,
There isn't a reduction in signal level on quad/octo's. A quad is 4xLnb's in one case.
It's very hard to say which lnb is best, impossible without knowing which dish you are using. As far as noise db ratings, a cheap 0.1db lnb will be out performed by a quality 0.3db lnb.
If you could post some more details about your dish, recommendations for a suitable LNB can be made.
rick1980 said:
...If you could post some more details about your dish, recommendations for a suitable LNB can be made.
Hi, the dish I have is an 80cm Orbital Dish
Technical Specification:
  • Dish Diameter: 740 mm x 840 mm
  • Gain 10.70-11.70 GHz: 36.8 dBi
  • Gain 11.70-12.50 GHz: 37.8 dBi
  • Gain 12.50-12.75 GHz: 38.5 dBi
  • Half Power Beamwidth: <2 degrees
  • Cross Polar Discrimination: >27 dB
  • Mast Clamp: 32mm-80mm
  • Elevation Range: 15-55 degrees
  • F/D Ratio: 0.6
  • Offset Angle: 25 degrees
  • Windloading @ 72 Km/h: 17.4Kg
  • Windloading @ 144 Km/h: 69.4Kg
  • Windloading @ 216 Km/h: 156.2K
is that enough info, lol, thats if all 80cm dishes with the 'Orbital' name is the same or moreless
Southern Satellite sells those dishes so might be an idea to ask him, but I dont think you would go far wrong with either of these :-
_http://www.southernsat.co.uk/index.php?l=product_detail&p=110
_http://www.southernsat.co.uk/index.php?l=product_detail&p=359
Hope that helps.:)
